Mudfish for OpenWrt is great. I currenty using FullVPN feature in OpenWrt. Since the FullVPN will route all the data through VPN, Is it possible to add a feature that a text area in the openwrt mudfish settings page? The user can populate the ip range they want, so that it will only route data through the designated ip. For example, I want to play a game and will route through a Mudfish node, but I want to watch Youtube or surf the internet at the same time, subscription plan doesn't provide good bandwidth. I know there is pay per traffic plan but it maybe will be used to much traffic I'm afraid, and of course the speed will be another problem as well. So if there is a feature like that does the partial routing that will be great.
You can try to Create Custom Item as refer Unsupported Games
- Make sure if the Expert Mode turned On
- Then create a Custom Item as input what you want to add routing rules to Mudfish using CIDR
