Not sure any other have ask the same question. Can Mudfish support PS5 platform? If can via router then can recommend any ASUS or Netgear router for this purpose? Thanks.
You can’t install Mudfish VPN directly on your ps5, but you can use it through a router or VM.
Check out the guide below.
