Mudfish having issues with Diablo 3 or Battle Net? If vpn is on, Battlenet won't connect at all. If I disable mudfish vpn, Battlenet connects just fine. Affects both v4.6 and older version 4.5. Turned off Windows firewall and ESET firewalls, same issue. Care to enlighten?
Please try to
- change your node https://mudfish.net/forums/6/topics/44662
- Connection Protocol in TCPs https://mudfish.net/forums/6/topics/37597
- run Mudfish with option lowercase `-s` then access to https://ui.mudfish.net:8282
- China https://mudfish.net/forums/6/topics/44662 https://mudfish.net/forums/6/topics/37597
