My Mudfish application exits each time I resume from hibernate on Windows 10. Is there a way to check what is happening?
It’s an expected behaviour. So at this moment whenever it’s waken up from the hibernation, Mudfish Launcher should be terminated.
If you want to stop it, no way with current implementation.
Thank you for the explanation. What would be the reason for doing it?
It was intended to prevent the IP conflict between users. Internally when a user connects the mudfish, the private IP is leased and it’ll be used as long as the user keeps connect.
However when a PC goes to the sleep and the leased private IP is inactive for a long time, its private IP could be leased for another user. So it means when a PC wakes up, its private IP on PC could be already gone and leased for another user. Without a termination of the program, both of users will encounter a issue of IP conflict.
