I am only able to login through the support link and when I try to connect Mudfish, the connection stalls at 48% and bunch of errors pop up.
Did not have an issue yesterday on 6/1/2024.
저도 현재 비슷한 증상이고 로그인을 여러번 시도하다가 보면 로그인이 되는 경우가 있는데 그렇다고 사용이 정상적으로 되지는 않았네요
Thank you for your feedbacks. I’m not sure that this issue is a temporary issue or not because the internal graph shows there’s huge spike of CPU loads in mudfish DB yesterday.
I hope this issue doesn’t happen again but I need to monitor this symptom a little bit more.
