Mudfish not connecting every other match
Hi. So I’m experiencing this bug where whenever my match ends, mudfish will just decide to not connect. I will have to manually re-open the game whenever it disconnects. It doesn’t show any notifications that it got disconnected, everything looks normal in the dashboard but I will notice my ping to be a lot higher than my previous game where mudfish was still connected. This bug does not happen with other boosters.
No this is definitely a problem with mudfish. It’s not just me who has reported this very issue. I’ve seen other people post about the same case. Other boosters don’t have this problem. Eternal Return Korea server, sometimes VPN doesn't work
@Scaff Umm… So are you meaning that it’s even same with Full VPN mode enabled?
If then, did you try to test with Full VPN mode + WFP Item mode combination before?
