Mudfish not working with FFXIV?
Hello! I’m not sure Mudfish is working for me anymore, the realtime RTT graph is always empty (see picture), the credit usage seems to be at 0 too.. I use the full vpn mode and I play on Primal data center.When I do the basic functionality test it says Mudfish is working fine but this seems really weird.
I’m having the same problem. Also on FFXIV, but trying to connect on Crystal data centre.
Edit: Oh never mind, I see that that is normal for FastConnect mode: FastConnect mode · MUDFISH
:frowning: It’s not good. If possible,
Could you please check that it’s even same with that?
It worked! Thank you very much!
Also worked for me, thank you very much!
