I’m trying to go through the singapore server. I dont mind using full VPN but it uses too much traffic
it seems 20 days ago you have already updated the game item? I saw this on the forum. sometimes it works and sometimes it doesnt when using the game item but full vpn is good all the time
If it works fine with Full VPN mode enabled, please send me some game packets using Packet Capture with Mudfish link while playing the game with Full VPN mode.
I have uploaded the packets
I’d left my answer on the packet dump topic you uploaded at Private Support menu. Please check it there. You can find your topics at https://mudfish.net/forums/iwrote link.
thank you. It seems mudfish is working but the game does something strange during matchmaking. If searching for more than 90 seconds in queue it will start looking for game outside of OCE. Is there a way mudfish can help with this behavior?
Weird… Is this (searching for more than 90 secs) also happening with Full VPN mode enabled?
I’m curious that this issue is only happening with the game item.
yes with FULL VPN too which is why I am also confused. It seems the game will force another region after this time. I have been mainly using FULL VPN only but also tested with the game item its the same
If it’s even same with Full VPN mode enabled, I’m not sure that Mudfish can solve this issue because it very depends on the game matching implementation of the game client…
is there a way for me to set mudfish with multiple locations depending on which the game picks?
Unfortunately, no. At this moment, Mudfish doesn’t ping mudfish nodes automatically depending on the game server location of the game client.
So the used need to set the destination explicitly.
