Mudfish shuts down by itself, randomly finding it closed when relaunching my games.
Then it’s not good… When this issue happens again, please check “Task Manager” to see which processes are terminated abnormally.
mudfish.exe
mudrun.exe
* mudflow.exe
If it works properly, all above processes should be running.
Really? Very very weird. Only a possibility of this scenario is that mudrun.exe (Mudfish Launcher located at system tray) is normally terminated by someone or program because only mudrun.exe terminates normally it kills mudflow.exe and mudfish.exe processes.
If one of process is abnormally crashed, other processes should be running.
When you get a chance, please send me log files (*.txt files) found at the mudfish installation directory to support@loxch.com email if this isuse happens again. I need to look into inside.
