im trying to use mudfish but whenever i install it an try to run it for ffxiv my whole connection start to slow down and makes it impossible to navigate, and not on my pc only but the problem is in all the devices i use on my network… I have full vpn mode off , simply added ffxiv as item and connected to that idk what to do, any possible fixes? thanks!
Could you please send me Problem Report while your issue is happening? I need to check the internal logs.
here i had mudfish opened but i had no items running but still had the slow down mudrun_stdout.txt - Google Drive and this one was while connected mudrun_stdout2.txt - Google Drive
Please check Problem Report and follow it properly. mudrun_stdout.txt
only includes the log of Mudfish Launcher so it doesn’t include other information I’d like to see.
