Mudfish Traffic Balance Abnormal Consumtion
Hii. Im using mudfish for AION2 game, which i always monitor the traffic balance . im pretty sure the usage is not more than 200mb because the tab said so. but when i disconnect it the traffic balance go down abnormal from 48GB to 45GB is this normal thing for mudfish that take 2GB + ? can you explain why ? i click on traffic tab 2.2gb which i dont understand why ? since im seeing in home page that i use no more than 200MB .. is it bug? can you check it for me?
im pretty sure the page do show me im not using more than 500mb a day. but this is insane
Please try to monitor your network traffic if possible. At this moment it looks like we need more information where this issue comes from.
And please visit ‘Account → Edit profile’ menu to enable the Connection Log feature to see where your traffics were used. You can find it at Sign In - MUDFISH: Acceleration As a Service link.
i just open the game itself, not doing a multiple tab like opening youtube,twitch etc.. using WFP Item mode. before i alrd tried login the game about 15hours+ and it only took 500-600mb i think that is normal. in this case im login the game about 4-5hours yet balance go down awry about 2.2gb which unbelivable for me :smiling_face_with_tear:
:slight_smile: In a view of Mudfish, it’s not easy why the traffics comes into Mudfish. When you get a chance, please try to monitor your network traffics using the above tool if possible.
