I used to use Mudfish to play Valorant from London to the Mumbai server, and my recent experience has been below average. Previously, I would get pings around 120-130 ms, but now I can’t get anything below 180 ms. I’ve tried basic mode, advanced mode, and multi-path mode. When connected, the RTT dashboard shows 150 ms, but in-game it’s 200 ms. When calculating the ping for multi-path mode, it shows around 128 ms, but I get nothing less than 170 ms using the same path. I have also tried reinstalling and resetting both Mudfish and Valorant. (Ping on left top corner in valorant)
If it works fine with Full VPN mode enabled, it means there’s something a problem in the game item of Mudfish. For that case, I need to collect some game packets using Packet Capture with Mudfish.
I have already tried with it and it still doesn’t work
Which a mudfish node did you use? And is CommanderWW
mudfish ID what you’re using? I tried to check your configuration but it seems it’s not what you’re using currently.
