Hello, I have been trying to use mudfish with proxifier. For some reason it doesn’t work even though it shows that the data is being passed through the node in the proxifier logs. the ping usually changed for other servers when I am using a singapore node for example. But nothing happens, I have shared my proxifier logs and settings below. I have also tried using it while running the mudfish launcher.
My data hasn’t changed neither has my ping, also I cannot seem to find anything in access log. The proxy checker says that it has access. Is there any option to set it to udp only or something?
Thanks.
