Hi. I have been playing Battlegrounds Mobile india from Middle East Using Mumbai Lightsale Severs. Recently it has stopped working. I Dont know the reason behind it. Earlier mudfish used to work like a gem. But that is not the case now. The pings are not constant & sometimes even disconnects randomly. By the way not only i am having the issue but also my friends are complaining about the same.
Expecting your swift reply in this matter.As it is a case of emergency.
Did you try to test with "IN Asia (Mumbai - Amazon Lightsail X) mudfish nodes? Its public IP are changed to another yesterday. However if it’s even same, I think that BGMI blocks a connection from the cloud computing providers such as Amazon, Google, Microsoft and etc…
So you might need to use other mudfish nodes unfortunately.
yes i saw your comment… Any other solution to this because the other nodes are having ping fluctuations. It sucks nd literally is affecting my gameplay… amazon lightsail was good
At this moment, it seems no proper way to bypass this issue if you’re using mudfish nodes on Amazon AWS instances. So as a workaround though I’m not sure that it’s helpful for you, I added the following new mudfish nodes:
IN Asia (Mumbai - G-Core Labs 2)
IN Asia (Mumbai - G-Core Labs 3)
IN Asia (Mumbai - G-Core Labs 4)
IN Asia (Mumbai - Psychz 4)
IN Asia (Mumbai - Psychz 5)
IN Asia (Mumbai - Psychz 6)
IN Asia (Mumbai - Psychz 7)
IN Asia (Mumbai - Psychz 8)
IN Asia (Mumbai - Psychz 9)
If you know any good (ping) providers, please let us know. I’ll try to lease a server and deploy the mudfish node if possible.
@weongyo Mumbai psychz works with low ping
I tested another vpn called octohide with Mumbai Nashik server that too have low ping.
If possible try to add more of these nodes and figure out which one is used by Octohide India Nashik server and kindly add few more nodes
@weongyo ping is high for psychz now. Most of the nodes are having high ping at times. I guess its due to server resources. Please do something.
Google 4 also works with low ping sometimes.
@akhilcinderella Thank you for your feedback. However do you mean that IN Asia (Mumbai - Google) or IN Asia (Mumbai - Google 2) mudfish nodes aren’t with the good ping while other google nodes have a good ping?
@weongyo yes, IN Asia (Mumbai - Google) or IN Asia (Mumbai - Google 2) are not having good ping. 3 and 4 works properly but sometimes it is overloading. Mumbai - psychz is now having high ping.
Mumbai - Oneprovider also works the best now.
The ones that works fine are Mumbai Google 3,4 and Oneprovider.
@weongyo thanks, oneprovider 2 and 3 and most of the psychz used to work.
Since yesterday everything is having very hightl ping and many nodes are down.
