my connection always drop ever
my connection always drop everytime i turn mudfish on. i check it on ping it said “reply from 10.254.14.1 destination host unreachable”, and when i exit mudfish, ping back to normal. its like mudfish interupting my internet connection or something, how to fix it?
ah sorry i forgot to said that it ussually perfectly working before (i was using mudfish about 7 months or something). this issue just start happening randomly about some weeks ago. also i didn’t change anything in my pc/mudfish. thx for ur answer anyway
Okay. However I’m not sure why at this moment. When this issue happens again, please check ‘Status -> Process’ menu to see the core logs. And let me know if there’s something warning or error.
한국 -> 북미 갈때 어떤걸 선택해서 구매해야하는지 물어보고싶습니다!
리그 오브 레전드로 찾아보시기 바랍니다.
문제점 보고서를 보내주셔서 정말 감사합니다. :-) 혹시 미꾸라지를 사용하시는데 문제가 있으신지요? 그렇다면 조금만 부연해 주시면 제가 좀 더 도움을 드릴 수 있을 듯 합니다.
