Without using my vpn credit it becomming less i only use it for playing battle ground mobile india . After disconnecting also the credit is becomming .its my second time in this month recharging because of this issue please anyone help
Please visit ‘Account → Edit profile’ menu to enable the Connection Log feature to see where your traffics were used. You can find it at https://mudfish.net/admin/user/modify link.
For your convenience, I’d reset your mudfish credits a little bit.
Thanks for your reply i will check it right now
