my ping goes up and down on 5E
my ping goes up and down on 5EWIN and won’t stay consistent. what do i do to fix this? it’s goes from 70-140 constantly
Please change your node manually based on FAQ - Nodes
China related
It’s recommended connect through over Hong Kong or Taiwan servers for bypass the Great Firewall but as you know we have barely methods to connect to China as poor nodes so
if you doubt the Great Firewall I think there’s no many options for stablize your RTT
Ok, I appreciate your advice. I am also having an issue with my internet sometimes when I am not even using Mudfish but it only happened after i started using mudfish. My internet doesn’t work sometimes for anything but games. Discord/browsers won’t work at all, how do i fix this?
Then check about Firewall Issues
