since 25/3/2022,it has some unusual real-time data traffic,and make my RTT double,it used to be 40
Did you try to change a mudfish node based on FAQ - Nodes section for your game item? Please check that it’s even same after changing the mudfish node to another.
I play cyphers (a S. Korea game)and only start with basic mode.
except google node(55 RTT),all the KR Asia (S. Korea)node has this situation .
Now i use HK node which only have 50 RTT, but I still miss my 40 Rtt S. Korea node.
I am live in hongkong but play without mudfish will more than 100ms RTT
Not easy to explain why for this case… Did you try to change Connection Protocols? Sometimes changing the connection protocol could be helpful.
