my wow is stuck on loading scr
my wow is stuck on loading screen
Please try to change Connection Protocol to TCP then change your node to the other except PBE. You’re on Subscription Plan so don’t worry to use normal nodes.
so its working but im getting over 900ms for uswest servers. is there any settings im missing?
You can pick a node that shows lower RTT avg/stdddev with flat graph
to optimize your connection.
Then turn on FastConnect mode
