Need suggestion, I tried to custom item for Bless Unleashed but seem not to work
Since there’s no Bless Unleashed Steam version for SEA server so I tried to do a custom one myself.
but it doesn’t seem to work, I thinks I got the IP right but not possible to connect.
this is the Process on Status tab
I hope this provide enough information
or if possible, please update Bless for new Steam SEA server because I thinks the one we have right now is the old one that already close a while ago
Thanks alot in advance
It seems your issue is caused by the wrong CIDR syntax. However why do you use 192.168.2.0/24 for the routing table?
192.168.0.0/16 is for the private network so I don’t think it’s a valid for the game server IP.
If it’s hard to create a custom item, please send me some game packets using Packet Capture with Mudfish link while playing the game with Full VPN mode.
I can analyze the packet dump if it’s available.
oh I don’t know about that, Thanks
I tried to check it from my Task Manager and it connect me there
Today I tried connect by .exe it can connect to the node but it seem like game can’t seem to connect
I’ll try this method first and will come back again later
Thanks alot :smiley:
I already upload a packet dump as you suggest
I don’t know where I should send my upload so I’ll put it here
https://mudfish.net/forums/7/topics/72608
I’d leaved my answer at other topic you created at Private Support menu. Please check it there. :slight_smile: You can find your topics at https://mudfish.net/forums/iwrote link.
