Nexon - Crazy Arcade block mudfish
I use Mudfish to play “Crazy Arcade” after connecting for about 5 minutes it disconnects
The publisher has blocked the mudfish software. You can try downloading the game here: https://ca.nexon.com/Support/Download.
I use other vpn software and it works fine
:frowning: This is not good. Then it means that you need to hide the mudfish process from the system. One of popular methods is
