Is it that there are no available nodes which are better than my local isp connection? Singapore
ping is ~96 in-game without mudfish
routing paths show ~100 ping
Please try to turn on “Include the result for the advanced mode” option which found under ‘Setup → Nodes’ menu. When it’s enabled, Today’s Pathes will show you the advanced results for route pathes.
However if you’re connecting to “AU Oceanic (Sydney)”, it seems your ping is good enough if I checked your RTT information.
