Usually when I start Mudfish it loads up to the page with the progress bar and Realtime RTT, Traffic, etc. now it just goes to the dashboard and I have to manually click the green “Connect” button to make it work.
Did you check ‘Setup → Program’ menu and click “Launcher” tab? At there, you can see ‘Auto Connect’ option so I think it’s what you’re looking for.
Ah I see it thanks, I don’t know how it got turned off.
