No Realtime Traffic and Realtime Traffic Usage
Hello. I’m using mudfish vpn to connect to Cabal Online (PlayCabal Private Server) and I am having issues. My traffic seems to be not working which results to high ping. I have the following configuration:
Game Server location: Europe (London - playcabal.online)
Node Mode: Basic Mode
Selected Mudfish Node: SG Asia (Singapore Azure)
Connection Method: Item Based, +FastConnect Mode
I attached the dashboard after 1 hour of playing. As you can see, Realtime Traffic and Realtime Traffic Usage is not working even if I hit the refresh icon on each tab. Thanks.
Please confirm that How to check the basic functionality works fine in your environment. It’s the first thing you should test.
Full VPN is working and it’s what I’m currently using to play Cabal. But it uses too much data and I can’t do anything in the background like playing music etc. since its gonna consume all my data in like a day.
I see. If it works fine with Full VPN mode enabled, it means that something the game server IP missed in the game item.
Thanks. Here is the packet dump.
https://mudfish.net/forums/7/topics/89074
I’d left my answer on the packet dump topic you uploaded at Private Support menu. Please check it there. :slight_smile: You can find your topics at https://mudfish.net/forums/iwrote link.
https://mudfish.net/forums/7/topics/89101
Hi. Please this is another packet dump I made. Thanks
Sure. Please check my answer at your packet dump topic. :slight_smile:
