빨리요!!!
취소합니다
In a mudfish, 3000 ms means the packet loss and I think your result is very dependent which mudfish nodes you’d picked.
So please pick a mudfish node carefully based on FAQ - Nodes. I think RTT stddev whose value is closer to zero is a key to pick a good one.
In mudfish, 3000 ms means the packet loss so it tells that your connection is unstable to mudfish node by unknown reason.
Please try to change it to another simply it should be applied when the item configuration is saved.
패킷 덤프 보내주셔서 감사합니다. 제가 아이템 업데이트를 해보았는데 한번 테스트 부탁드리겠습니다. 시도해 보시고 여전히 제대로 동작을 하지 않는다면 말씀해 주세요.
