No subject
Ooops. Then could you please show me the route pathes you’re seeing? I need to check the backend of Mudfish.
https://gyazo.com/189c0118b4b0c5ca54f5409444715e59
Haven’t tried every single one but the only one that yields an accurate ping is Vultr 4 (I’m sure the others do it as well). I think somewhere around 230ms is probably the geographical limit to my ping, so not sure why they show lower amounts.
Thank you for these information. I’ll check it again because its calculation is little bit weird when I checked the ping test.
Thanks Ioxch, the amount of credits you added just exceeds the amount this account lost.
You could just ignore this problem of the account if it takes your time too much. However I recommend checking it, there could be cases like me, and hope you can fix the problem!
Thanks again!
p/s: The game was Crazy Arcade, not Maple Story (I corrected the first message)
Sorry for answering in English because we’re not offering technical support with other languages.
Please check MUDEC_00044 and MUDEC_00045 error links for workarounds. :slight_smile:
OK it’s fine i just solved the problem
