미꾸러지 설치중에 No TAP-Win32 Driver
미꾸러지 설치중에 No TAP-Win32 Driver found. 오류가 계속 뜨네요.문서를 보고 시도도 해봤는데 잘 되지도 않습니다.
[Device Install (UpdateDriverForPlugAndPlayDevices) - tap0901]
Section start 2018/09/04 13:25:45.864
cmd: “C:\Program Files\TAP-Windows\bin\tapinstall.exe” install “C:\Program Files\TAP-Windows\driver\OemVista.inf” tap0901
ndv: INF path: C:\Program Files\TAP-Windows\driver\OemVista.inf
ndv: Install flags: 0x00000001
ndv: {Update Device Driver - ROOT\NET\0000}
ndv: Search options: 0x00000080
ndv: Searching single INF ‘C:\Program Files\TAP-Windows\driver\OemVista.inf’
dvi: {Build Driver List} 13:49:18.602
dvi: Searching for hardware ID(s):
dvi: tap0901
sig: {_VERIFY_FILE_SIGNATURE} 13:49:18.630
sig: Key = oemvista.inf
sig: FilePath = c:\program files\tap-windows\driver\oemvista.inf
sig: Catalog = c:\program files\tap-windows\driver\tap0901.cat
! sig: Verifying file against specific (valid) catalog failed.
! sig: Error 0x800b0109: A certificate chain processed, but terminated in a root certificate which is not trusted by the trust provider.
sig: {_VERIFY_FILE_SIGNATURE exit(0x800b0109)} 13:49:18.711
sig: {_VERIFY_FILE_SIGNATURE} 13:49:18.712
sig: Success: File is signed in Authenticode™ catalog.
sig: Error 0xe0000241: The INF was signed with an Authenticode™ catalog from a trusted publisher.
sig: {_VERIFY_FILE_SIGNATURE exit(0xe0000241)} 13:49:18.744
dvi: Created Driver Node:
dvi: HardwareID - tap0901
dvi: InfName - c:\program files\tap-windows\driver\oemvista.inf
dvi: DevDesc - TAP-Windows Adapter V9
dvi: Section - tap0901.ndi
dvi: Rank - 0x00ff0000
dvi: Signer Score - Authenticode
dvi: DrvDate - 11/05/2014
dvi: Version - 9.0.0.21
dvi: {Build Driver List - exit(0x00000000)} 13:49:18.750
dvi: {DIF_SELECTBESTCOMPATDRV} 13:49:18.750
dvi: Default installer: Enter 13:49:18.752
dvi: {Select Best Driver}
dvi: Class GUID of device changed to: {4d36e972-e325-11ce-bfc1-08002be10318}.
dvi: Selected Driver:
dvi: Description - TAP-Windows Adapter V9
dvi: InfFile - c:\program files\tap-windows\driver\oemvista.inf
dvi: {Select Best Driver - exit(0x00000000)}
dvi: Default installer: Exit
dvi: {DIF_SELECTBESTCOMPATDRV - exit(0x00000000)} 13:49:18.755
ndv: Force Installing Driver:
ndv: Inf Name - oemvista.inf
ndv: Driver Date - 11/05/2014
ndv: Driver Version - 9.0.0.21
sto: {Setup Import Driver Package: c:\program files\tap-windows\driver\oemvista.inf} 13:49:18.759
inf: Provider: TAP-Windows Provider V9
inf: Class GUID: {4d36e972-e325-11ce-bfc1-08002be10318}
inf: Driver Version: 11/05/2014,9.00.00.21
inf: Catalog File: tap0901.cat
sto: {Copy Driver Package: c:\program files\tap-windows\driver\oemvista.inf} 13:49:18.765
sto: Driver Package = c:\program files\tap-windows\driver\oemvista.inf
sto: Flags = 0x00000007
sto: Destination = C:\Users\Hong\AppData\Local\Temp{f4ff9989-91f3-ff43-99b1-dc8441d0d0f0}
sto: Copying driver package files to
음… ㅠ.ㅠ 글쎄요… 지금 보여주신 로그의 경우 format 이 깨져서 정확하게 보이질 않습니다. !!! 와 같은 메세지가 쳐져 있는 것이 보통 원인인데, 해당 부분을 googling 해보시길 권해드립니다.
