Anyone else experiencing connection problems with Cabal PH? The nodes don’t work for me except Cloudsigma which the game often exit.
If I know correctly, it restricts the connection from the outside of PH. So I think it’s required to use mudfish PH nodes to play the game if I know correctly.
Are you meaning that sometimes the game is abnormally terminated while using the mudfish? Did you check ‘Status -> Process’ menu to see “Core” log section? Please check there’s an error or warning message there.
@dmitri2017 Is it still same? Recently I’d changed all public IPs again. I hope it works fine but not sure it’s.
Hi weongyo,
Right now only cloudsigma 2 is working for me. Hopefully, it will not show any connection problems. It would be good if all nodes would work in case I need to change nodes. I’ll try the rest and keep you updated. Thank you for your prompt response.
@dmitri2017 Okay. I’d changed other nodes too. When you get a chance, please test other mudfish PH nodes. FYI I didn’t change the public IP of cloudsigma 2 yet.
