None of the JP nodes work with
None of the JP nodes work with Japanese Black Desert Online since today.
Symptoms:
  1. Able to login into BDO web site, authenticate and start launcher.
  2. Launcher takes significantly much more time to do it’s stuff (load images, file check/update, etc.)
  3. Can enter the game but it takes much longer to login and it’s unplayable - all online features don’t work (can’t check auction house, can’t receive login bonuses, can’t see other players, etc.)
I tried few other paid and free Japanese VPNs and they worked just fine, so apparently the issue is with Mudfish nodes.
Not sure that the game publisher blocked mudfish japan nodes. :frowning: However did you try to change Connection Protocols to TCP based?
Or please check that with Full VPN mode enabled it makes any differences.
I tried both fast connect and full vpn. Didn’t make any difference. Can’t say if now the issue has been resolved or not, since I stopped playing on JP server
