So I was trying to set my WoT item to lower the ping from the EU server. then while testing through World of Tanks Item - MUDFISH: Acceleration As a Service I see that somehow JP nodes like Osaka - Azure has lower RTT avg compared to DE Europe nodes. If my understand is correct, lower RTT value is better? Will try it with jp node first but any tips on how to set up a good node for WoT for the ping drop?
Could you please check World Of Tanks link when you get a chance?
