Okay so simply… gyazo.com/69513b628a04067fb rtt to e736b2d82cd70b4 take a look at this screnshot it went from 185rtt to 1045rtt… ?
How to turn on full VPN mode?
Run Mudifsh Launcher as Administrator and sign in with your mudfish
account.
Moves to ‘Setup -> Program’ menu then select ‘Full VPN’ tab.
Select a node you’d like to use and save the configuration.
Restart
is required to be applied.
Please make sure that your public IP is changed with visiting
myip.mudfish.net URL. If it works correctly, it’d show proper
messages.
Ťthank you!
If your data plan is PPT (Pay Per Traffic) and you’re using Full VPN
mode, please use this feature carefully because it could consume a lot
of mudfish credits if you uses it wrong.
ok
