Hello. Any way to access the dashboard from client opened without Edge installed? Because i don’t have Edge and login/dashboard directly from Firefox is not allowed.
Oh and… Of course i don’t want edge running
nvm
Solved with EdgeDeflector
(btw in win10 because is blocked in win11)
This is very weird… Did you use http://127.0.0.1:8282 URL to access the mudfish dashboard? It should work without any problems…
Well, looks weird because Edge usually run in background,and we don’t see what happen behind but is required to redirect some links.
Without edge running in background, without store, with a debloated windows running, the result was a popup message to indicate edge requirement.
Anyway, solved for now. Thanks
