Osaka TinMok node latency
I would always use the Osaka TinMok nodes for Granblue Fantasy since they would average 85ms from Hawaii to Japan, which is over 40ms lower than the Tokyo nodes. However within the past week or so The Osaka TinMok node latency from my end just about doubled, averaging 150-190ms with a bit of packet loss now. Latency to the Granblue servers still average about 150ms without mudfish running which hasn’t changed but current fastest node options are about the same latency now that I can’t really use Osaka servers. Is this an issue with my ISP?
@Minoru As far as I know, there’s no physical changes on Osaka Tinmok mudfish nodes. But I think something is changed in the internet routing or some submarine cable issues are happening.
Not sure what’s best mudfish nodes are best for you but please try to check to your ISP whether there’s a international routing issue.
