Overwatch Nodes Wrong
Past week or so I’ve been trying to connect to US-West (Los Angeles) from Australia, Sydney.
However the path/node routing for RTT is presenting as if I’m in Korea (image attached).
The game will either not let me into any servers, or put me back into Sydney servers.
I’ve tried changing the server, eg Singapore will work, and US-east tentatively but over multiple days this has been the result for US-west. Manually selecting a node I previously used (eg US-W LA Aoyou 1 to 13) does not let me connect to the game.
I am using WFP mode if it is important.
Umm… :frowning: It looks like the game item used old IP relocated to another country. I’d updated the game item for this locatioin. When you get a chance, please test this issue again.
Thank you for your feedback.
Thanks for checking it.
This is the new error when saving US-West Los Angeles in the config, and the node calculation does not finish. I confirmed that calculating RTT to Singapore server for example still works. I think also US-East does not work.
Update: tested it again without changing anything and it seems to be working now :slight_smile:
