Overwatch ping higher than shown
It reports as having 105ms to Amsterdam. I get 125ms ingame. Also the RTT calculator seems to be incorrect for advanced mode since it says the lowest I can get is 125 (145 ingame) when Auto Select → FR Marseille gives me 105 (125 ingame).
Full VPN mode doesn’t support the advanced mode does it?
No. It doesn’t support it in Full VPN mode.
