it has UDP connections problems
Sorry for this inconvenience. When I checked your custom item, it seems you removed P:xxx.exe option and uses CIDR rules instead. Is it working fine?
I’ll try to test little bit more for your case whether UDP connections for P:xxx.exe works fine or not. Thank you for your feedback.
Yes I have to capture all ip it connected and manually added
