I used to have 32ms ping long ago after connecting to mudfish nodes but after I came back recently, it is not lowering my ping from 60-120ms.
I’ve read in Paladins subreddit that they have moved servers from HK/SG to JP for a while now, but server location options in mudfish only has HK and SG for Asia.
Even if I connect to HK servers using HK nodes, nothing happens.
If it works fine with Full VPN mode enabled, it means there’s something a problem in the game item of Mudfish. For that case, I need to collect some game packets using Packet Capture with Mudfish.
