참 힘드내요…
PC성능
윈10 Pro
Intel i7-8700
RAM 16G
64bit OS
한번 설치는 되었고, 설정하다가 100%는 떳지만 Full-VPN이 설정되어있는것 같아
초기화 해보니 10%에서 진행이 안되어 언 인스톨을 하여, 다시 인스톨을 하니 애러가 뜨고 더 이상 안됩니다.
사용목적 게임은 로스트 아크입니다.
답변 기다리겠습니다.
감사합니다.
애러네용입니다.
Stop MUDFISH Core process.
Stop MUDFISH Flow Controller process.
Stop MUDFISH Launcher process.
Stop Mudfish first
Output folder: C:\Program Files (x86)\Mudfish Cloud VPN
Extract: mudadm.exe… 100%
Extract: muddiag.exe… 100%
Extract: mudfish.exe… 100%
Extract: mudflow.exe… 100%
Extract: mudrun.exe… 100%
Extract: mudrun_new.ico… 100%
Extract: dbghelp.dll… 100%
Created uninstaller: C:\Program Files (x86)\Mudfish Cloud VPN\uninstall.exe
Extract: devcon.exe… 100%
Extract: tap0901.sys… 100%
Extract: tap0901.cat… 100%
Extract: OemWin2k.inf… 100%
devcon.exe hwids returned: 0
Remove old miniport adapter
No devices were removed.
devcon remove tap0801 returned: 0
Install miniport adapter
Device node created. Install is complete when drivers are installed…
Updating drivers for tap0901 from C:\Program Files (x86)\Mudfish Cloud VPN\OemWin2k.inf.
devcon.exe failed.
devcon install returned: 2
devcon cumulative status: 2
Create folder: C:\Users\USER\AppData\Roaming\Microsoft\Windows\Start Menu\Programs\Mudfish Cloud VPN
Create shortcut: C:\Users\USER\AppData\Roaming\Microsoft\Windows\Start Menu\Programs\Mudfish Cloud VPN\Mudfish Launcher.lnk
Create shortcut: C:\Users\USER\AppData\Roaming\Microsoft\Windows\Start Menu\Programs\Mudfish Cloud VPN\Uninstall Mudfish.lnk
Completed
