Hi! Got back into trying Mudfish again after connectivity issues in Tree of Savior recently and re-encountered an old problem I once had in Blade and Soul NA several years ago. Basically what happens tends to be the TAP-V9 Virtual Adapter ends up being seen as Unidentified Network while Mudfish Dashboard indicates Setup is stuck at 10%.
Self-Diagnosis shows that the connection to the KR UDP and the last private network test both fail often, and I’ve tried several setting changes such as picking different UDP ports and having the -I extension modifier on to no avail. Having the VPN go full seems to work fine but things time out more often for some reason. Can capture logs if needed.
Thank you!
