Normal i got 70-80 ping connecting to Elemental server for FF14 but now it has become 90-100 which is not that short from the normal 110 ping. It’s been like that for the past 2 weeks. And also path calculation took too long to get new info compare to before.
Thank you that was slower but i manage to get a grasp on the ping.
