PLAYERUNKNOWN'S BATTLEGROUNDS
PLAYERUNKNOWN’S BATTLEGROUNDS
plz add this game
not working
Done! I uploaded the packets!
Weird. I just tried it and it works too, but it doesn’t show anything on the Realtime RTT graph. It’s weird. loxch, can you please fix the PUBG item? it still doesn’t work with the game but for some reason, the Overwatch item works with PUBG but it shows no feedback on the RTT graph.
It could be a known(?) issue because both the game server of Overwatch and PUBG are on Amazon EC2. :-( So please keep in mind that you should not activate (turn on) both items at same item.  Please try to test it again because now I’d updated the game server again.
Are you running Mudfish with FastConnect mode?  If then please turn it off to see the realtime RTT graph.
Please add South America servers… (SA)
To add new game server, I need some game packets to analyze.
:slight_smile: Thank you for sending the packet dump. Based on your packet dump, I had updated the game item. Could you please test with it? If it is not working properly, please let me know.
However which game server location did you try to connect while dumpthing this packet?
자세한 해결책은 MUDEC_00044MUDEC_00045 오류를 참고 바랍니다. :slight_smile:
처리해 드린 것으로 보입니다. :slight_smile: 확인해보시고 문제가 있으시면 언제든지 답글 부탁드립니다.
