Please help jp Hokkaido server
When I connect to Jp Hokkaido server and check my ip it say im in china i tried full vpn but it didn’t work!
How did you check your public IP while mudfish was running? It seems you’re using “JP Asia (Hokkaido - SakuraNet)” mudfish node. Did you follow How to check the basic functionality and test with this node?
I tried everything and still didn’t work I use https://whatismyipaddress.com/ to check my location and when I connect it says that Im in china instead of Japan
Could you pleas send me Problem Report? I need to check the internal logs.
However please check IPv4 part instead of ‘Country’ part because it could be inaccurate.
