Please fix my issue
When I try to connecting mumbai amazon server’s it’ can be connect, but after trying to start match in bgmi it’s stuck in loading screen,after that it will came back to lobby ,and game shows server disconnected 🥲
Did you try to test with "IN Asia (Mumbai - Amazon Lightsail X) mudfish nodes? Its public IP are changed to another yesterday. However if it’s even same, I think that BGMI blocks a connection from the cloud computing providers such as Amazon, Google, Microsoft and etc…
So you might need to use other mudfish nodes unfortunately.
Other mudfish nodes also getting high ping,no stable nodes available in mudfish
If there’s a mudfish node which allows your connection, I think you can try to test with Advanced Mode. For example you can try to connect like “User → Mudfish A → Mudfish B → Game server”.
