PoE 2 Inconsistent SEA nodes
Trying to pick close HK nodes and its either the nodes don’t let me load into hideout or let me log in, but really bad ping spikes jumping from 30ms-300ms every tick
Sometimes the node works normal for an hour then starts spiking ping or stops working and sometimes Mudfish shows stable ping in Realtime RTT but in game is spiking and all over the place.
Having to swap between nodes every minute checking to see if a node work is getting really tiring looking to get a fix for this if possible, this has been happing since 0.5 launch.
Hello GabeDeer,
I’m sorry to hear about the ping spikes and instability you’re experiencing with the HK nodes.
Could you please confirm if the issue is the same with Full VPN mode enabled?
If it works fine with Full VPN mode enabled, it means there’s a problem with the game item of Mudfish. For that case, I need to collect some game packets using Packet Capture with Mudfish to fix the routing.
Please let me know the result so I can assist you further!
Hi, tested with Full VPN mode and still getting the same issue, cant login into the game and getting kicked out when trying to load in my characters
Hi GabeDeer,
Thank you for testing that. Could you please first verify your setup by following the How to check the basic functionality guide?
If the basic functionality test passes successfully, but you still can’t log in while using Full VPN mode, it is highly likely that the specific Mudfish node you selected is being blocked by the game server itself.
Please try switching to a completely different node to see if the issue persists. Let me know how it goes!
Hi,
Tested full VPN with the proper setup and it seems to be working fine after a few hours of gameplay.
Please let me know if the packet dump is needed to help this issue
I’m really glad to hear that it is working fine with Full VPN mode!
Because Full VPN mode resolves the issue, it confirms that we need to update the routing for the game item itself. Therefore, a packet dump is definitely still needed to fix the root cause.
If it is possible, please capture the game packets while playing and send them over to us. Thank you for your help!
Thank you,
I have sent a packet dump via the private support
I’d left my answer on the packet dump topic you uploaded at Private Support menu. Please check it there. :slight_smile: You can find your topics at My Topics link.
