Is it possible to use SOCKS5 with IP based authentication instead of a username/ password?
Please refer to the guide below.
@jmham Thank you. Would the same method apply for Linux as well? i.e. I wont have to actually connect to any particular node through the mudfish app but will be able to use the SOCKS5 proxy using the internal IP of the node.
My answer is no if you trying to connect without mudfish app. If you want to connect mudfish nodes using their public IPs, the user/pwd auth is only a method to access.
