I’m playing on mobinogi’s private server, I bought equip but this server is not in the server list, so I’m trying to set the node for the server location, will this work?
If not, is there another way to use it?
I noticed there are other private servers on the list, can you add the one I play on?
I’m playing Auranogi and the server location seems to be in Arizona, US West.
Auranogi - a Mabinogi private server — Auranogi - Mabinogi 私人服務器
我玩的是mobinogi的私人伺服器,我買了裝備,但這個伺服器並不會在伺服器列表裡,所以我嘗試設置伺服器位置的節點,這樣是會有效的嗎?
如果無效,是否有其他使用方法?
看列表中有其他私人伺服器,是否可以請你們添加?
玩的是Auranogi,伺服器位置似乎在US West的Arizona
