filex
September 6, 2019, 4:22am
1
Problems with node (US WEST GOOGLE, OREGON) .
I have a problem with a node that doesn't work well for me and I try to send it to the blacklist.
The problem is that it persists in appearing if I leave the Final Fantasy XIV item automatically.
Can you help me?
What about picking your whitelist as reversed list?
filex
September 10, 2019, 11:03am
3
It has taken about 5 days, finally if it was removed from the list.
weongyo
September 17, 2019, 2:23am
4
Weird... Are you meaning that US West (Oregon - Google) node is on the recommended pathes for the game item even if it's blacklisted? If then I need to check the code little bit because it's unexpected. :-(
filex
September 17, 2019, 12:37pm
5
That's right, even after removing it, it took several days, in automatic selection, to be removed. I had to manually select the node to skip it
weongyo
September 21, 2019, 1:33pm
6
Okay let me look at this issue little bit more. Thank you for your feedback!.
