Process uncheck for blade and
Process uncheck for blade and soul taiwan
Then please check your Task Manager of Windows after launching mudfish.  After sign-in, you should see three processes:
 mudfish.exe
 mudflow.exe
* mudrun.exe
Is it all running?  If then please check “Status -> Process” menu to see detailed logs whether there’s a warning or error.
i have another problem. when im MAGNIFYING nodes. nothing appears in the list but it says it has 12 ENTRIES. whats happening?
음… 혹시 어떤 게임을 하시는데 해당 이슈가 있으신지요? 기본 동작 여부 확인 은 제대로 동작하는지 확인 부탁드립니다.
