hi, new member here
I use mudfish to connect my ps4 so if I m not wrong my only choice is full vpn. No ?
So I set up full vpn and tried muddish nodes located in my country and neighboor countries.
Connections are always slow. like 7-8 mbit download 1 mbit upload.
When I enable fastconnect mode. Speeds get higher but this makes my nat type 3. which needs port forwarding and this is not possible I think.
Could you tell me if am I doing anything wrong ? or what can I do to accomplish my goal ?
Thanks
It depends how you set up mudfish. If you checked Internet Connection Sharing with Mudfish document and set up on your laptop or desktop, I think Full VPN mode is only an option to apply PS4.
However if you have a OpenWRT based router, you can install mudfish packages for routers. So you don’t need to worry about Full VPN mode.
What’s your mudfish ID? @hakanarmagan I can’t find your mudfish ID.
If you need to set up Port Forwarding, please note that you can’t work with it if you’re using Mudfish. Mudfish server doesn’t perform the port forwarding so you’ll encounter NAT issue at the end if you’re using with mudfish.
