Hello, I wanted to ask is it possible to connect to the public nodes via HTTP proxy, like you can with Mudfish nodes?
Please refer to the link below.
Yes, I know how to connect using proxy with normal mudfish nodes. But can you do the same using public nodes?
Yes, the public node is not able to access via HTTP proxy because we do not provide it.
Will that be available in the future?
Unfortunately nop. As you might guess, the public nodes aren’t operated by mudfish. It means it’s at out of our control. So we can’t add HTTP proxy feature.
